TractorLinks.com
Show Parts for Model:
Re: WD 45 a Plowing Machine
JohnDeereM50
09-11-2012 18:12:44
If you use all Snap-Coupler implements the WD45 needs no extra weight added at all. Allis-Chalmers made anything you could think of Snap-Coupler.
Kelly MT
09-14-2012 22:31:52
 Re: WD 45 a Plowing Machine in reply to JohnDeereM50, 09-11-2012 18:12:44
Yes, I've got a Snap-Coupler post hole auger for my WD-45 Diesel. Works real good. PK
bg/mo
09-11-2012 19:11:23
I can see where he needs the extra weight, with our 45 and snapcoupler plow set as deep as it will go tractor is clawing for traction.
JohnDeereM50
09-11-2012 19:18:35
 Re: WD 45 a Plowing Machine in reply to bg/mo, 09-11-2012 19:11:23
Traction Booster in working order?
Engineut2
09-12-2012 11:59:57
 Re: WD 45 a Plowing Machine in reply to JohnDeereM50, 09-11-2012 19:18:35
With mine...I have even removed ALL the spacers from the spring clamp, so the Main spring is compressed as far as it will go and I Still haul back on the Hand Clutch lever, to help keep the front as low as I can..and that IS with the Hydraulic lever DOWN, all wheels Loaded and a RR Iron across the front ( In Jack-Wax )..still in 2nd Gear, tho..!
Clyde..
