TractorLinks.com
Show Parts for Model:
Re: CA ignition re-do
Kip-Utah
08-30-2012 10:22:37
I assume that you are using a distributor & not a magneto...If so yes you use the same one for all early A-Cs with distributors. Kip
OldMoIron
08-30-2012 11:46:20
 Re: CA ignition re-do in reply to Kip-Utah, 08-30-2012 10:22:37
Thaks, Utah I contacted Oreilys they having hard time looking it up. I called Yesterdays tractors parts dept they had one in hand and its on the way.
Brian Jasper co. Ia
08-31-2012 15:33:03
 Re: CA ignition re-do in reply to OldMoIron, 08-30-2012 11:46:20
They are sensitive to the resistance of the primary side of the coil. It can't be lower than 3 ohms. If it is, you need to add a ballast resistor, or get a different coil. I have the Pertronix on my CA and their Flamethrower coil just to be sure they are compatible. I also run the plug gaps at .045. Made a big difference in idle and starting.
OldMoIron
08-31-2012 16:25:59
 Re: CA ignition re-do in reply to Brian Jasper co. Ia, 08-31-2012 15:33:03
what plugs and wires do use on it, thanks
