clutch adjustment on d15allis model #1302
Tractor does not want to pull unless I idle it down and it still slips. How do I adjust it. It was doing great until I bushhogged 10 acre field.
Do you know it's the engine(foot) clutch? I'm assuming that's what you're asking about.
The rod that goes forward from the foot clutch pedal into the housing is threaded into a block on the end of the clutch operating lever. You can un pin the back end, and turn the rod. However, if the internal adjustments already had the clutch lever back against the housing, you won't gain anything.
