Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 201 into a 226
[Show Entire Topic]  [Return to Forum]
Aaron SEIA
08-28-2012 14:40:09
67.55.181.57
I think an offset grind involves welding up the outside of the rod journal. After that is done, the crank is ground again only this time it is ground for a longer stroke. Can be done to a point to gain stroke without needing the lengthen the actual throw of the crank. No idea how much can be added to the stroke doing this, but thats my understanding of the process.
AaronSEIA
[Reply]   [No Email]
jd plowboy
08-28-2012 14:48:15
69.160.179.211
 Re: 201 into a 226 in reply to Aaron SEIA, 08-28-2012 14:40:09
the welding on the crank is adding stroke to it. offset grinding is you take a 45 crank with has a rod journal size od 2 3/8 inch. you take that and grind off the bottom side of the journal to a 2 inch rod size. that way you are taking 3/8 inch off the bottom and throwing it to the top so you gain 3/8 of and inch stroke making it 4 7/8 inches. the journal has to be ground with the same angle on it as it has and if it is done wrong when you roll the engine the rod will hit the sleeve. you have to get a set of rods from a wd45 buda diesel which has a 2 inch rod journal. then you get a set of wd or wc flattop pistons but the only problem is you have to make a wrist pin bushing cause they are no longer made and make it a floating pin. this puts the piston 400 thousandths from the top of the block.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
