TractorLinks.com
Show Parts for Model:
Re: Need help diagnosing white foam in radiator on a WD...
old
08-26-2012 08:53:12
Could well be a blown head gasket and to see if it is try this. Take one plug out at a time and start the tractor. If after you have done that the foam stops with one plug then you know it is a head gasket since it will not cause pressure into the cooling system and you will also know which cylinder it is blown at
Zachary Hoyt
08-26-2012 08:55:56
 Re: Need help diagnosing white foam in radiator on a WD... in reply to old, 08-26-2012 08:53:12
That is a neat way to check. I was typing at the same time as you.
Zach
old
08-26-2012 09:52:54
 Re: Need help diagnosing white foam in radiator on a WD... in reply to Zachary Hoyt, 08-26-2012 08:55:56
Yep and it tells you which cylinder is the one that has the gasket blown at and it works with the foam problem of the ones that you get bubbles in
