Gents
My Allis C has an issue and I cant work out what it could be ? it starts fine and sounds good, but take it for a drive and after one mile or so it reves up starts knocking and stops,"its asif the engine has siezed" after 5 minutes or so it starts back up and will drive a little before repeating and stops, I thought it was the magnito and had it completely refurbished but with no avail, no water in the oil and no oil in the water and tempreture is normal when she stops.
Has eny one had this problem before ??
There is a wine in the gearbox probably the main bearing and I was wondering if this could be the problem if the bearing siezes up stoping the engine from turning and giving the impression that the engine has siezed ??
if the big ends are worn would this cause this problem ? or coulfd it be a stuck valve??
Your thouhts would be appreciated
John U.K
John U.K
