Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Allis
JMS/.MN
08-24-2012 08:46:35
Knocking and seizing sounds like a bad bearing on the crank. Look to that before the crank is ruined beyond repair. Might already be if you"ve done it more than once.
Drak
08-24-2012 11:05:04
 Re: Allis in reply to JMS/.MN, 08-24-2012 08:46:35
Thank every one for all your advice, I am not home at the momment but will do as you advise and check the crank shells, can i change the bearings without removing the engine (just remove the oil pan) or is it advisable to remove the engine.
I was also thinking may be find a diesel engine any one done this ??
JMS/.MN
08-24-2012 11:55:44
 Re: Allis in reply to Drak, 08-24-2012 11:05:04
You can replace rod journal bearings without removing the engine, but you may have a main bearing out......that necessitates engine removal.
