Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Lube Failure and Rocker damage
[Show Entire Topic]  [Return to Forum]
d13series2
08-18-2012 02:57:48
66.87.7.152
I have 3 "good" sets in my parts pile. All of them show shaft and rocker bushing wear to some degree. The bigger problem is the unavailability of rocker arm bushings - if they"re not tight to the shaft oil just runs out the end rather than lubing the shaft and being forced up the rocker to lube the valve and pushrod.
I figured a precision shaft and new brass (not Oillite) bushings, drilled to feed the upper rocker, would be better than another used part that"s already on the path of failure.
I actually thought of rerouting the oil line to feed the shaft directly but that still would leave the clearance problem, would have to flood the upper and starve the cam/mains to get adequate oilling.
[Reply]   [No Email]
steve(ill)
08-18-2012 18:57:38
74.36.188.36
i have rebuilt 3-4 different B motors and have seen shinny spots on the shaft and small wear on the rocker arms. Seems like it was only a couple thousandths. Maybe im lucky, but i just cleaned them up and reinstalled. Seemed to oil o.k. Some of it might be the end plates on teh pump itself. Smooth plates with very minimal clearance will increase the flow available to lube. As Dave said, the tube inside the filter is the "restrictor" that allows a small amount to blead off thru the filter. I think the tube has 1 or 2 of a 1/8 inch hole in the top. No tube or big hole will cause low flow / low pressure.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
