Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: AC model C - coolant in oil
old
08-13-2012 19:28:02
Could be part of an o-ring but not real likely because if it was the sleeve would most likely leak all the time. As for the head gasket it seals the top of the sleeves and can be easy to leak there if the sleeves do in stick up just a very little bit. The sleeves should sit up just enough that if you run your finger nail over them you should catch you nail on the sleeves. If not then that could be your problem BTDT and had once where the block was planned with the sleeves in and that in turn cause the sleeves to leak
Copyright © 1997-2015 Yesterday's Tractor Co.
