1940 allis w.c.
If you are running a magneto ignition it's important to use metallic core (non-resiter) wires and non-resister plugs. I like Autolite 295 plugs
Valve maybe set to tight and that will cause a come and go type skip to an engine as it heats up a valve or 2 will not close all the way so you can get a skip from that
