Compression on CA
The compression will be about the same as with the factory sleeves and pistons you just are getting a few more cubic inches of engine so the HP will go up a little bit
It will be in the 100 pound range. To many variables to give sure fired answer. To bring the compression up to a larger degree you will need to make the firing chamber smaller.
You can get there in two ways or both. You can get .200 off the head and use a domed piston to enter the firing chamber.
I did both to my pulling B and C.
I have been looking for doomed pistons and not having much luck, could you point me in good direction, got the head work figured out. thanks
The only domed pistons you will find for this engine will have to be a special order from the hot rod custom piston manufactures or having a machine shop TIG and machine them to fit your application. Both are costly.
I did my own having a tool shop with the equipment.
