Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: AC model C - coolant in oil
[Show Entire Topic]  [Return to Forum]
Dick L
08-12-2012 06:41:43
50.51.170.62
If you diden't have the engine running when you pressured the system you could very well have an air pocket in the top of the head water jacket. You would need to put oil in the core plug pocket and look for bubbles to be sure.
If the engine is running with antifreeze leaking on the bottom side the oil would become milky and you would not see a color in the core plug pocket.
[Reply]   [No Email]
Noah in IA
08-12-2012 14:13:41
166.181.3.69
 Re: AC model C - coolant in oil in reply to Dick L, 08-12-2012 06:41:43
Dick L-
I did not have the engine running when pressure testing. Per your suggestion, this morning I filled the three core plug pockets with oil and re-pressurized to 7 psi - still no air bubbles or coolant leak. I then proceeded to drain all the new oil I had just filled it with and then drop the oil pan. I would estimate at least two cups of water/antifreeze poured out the drain plug before uncontaminated oil started to flow. Next, I again pressurized the radiator and looked up into the engine to check for leaks around the cylinder sleeves - still nothing. Now I am thoroughly confused! - how can it be that after changing the oil, driving it back into the shed, and then doing various pressure tests that I could accumulate two cups of water in the oil pan and now when I pressurize the system with no oil pan attached that I see no coolant flowing down into the open cavity where the oil pan would be? Please forgive my ignorance as I'm a novice at engine work, but I thought that regardless of the leaks location I would see antifreeze drain back to the oil pan. Any advice? Do I need to pull the head next and inspect the head gasket? Thanks again for any advice!
[Reply]  [No Email]
Dick L
08-12-2012 18:25:18
50.51.170.62
 Re: AC model C - coolant in oil in reply to Noah in IA, 08-12-2012 14:13:41
Could be a bad head gasket that takes compression to blow the water into the oil.
[Reply]  [No Email]
old
08-12-2012 14:24:50
209.86.226.34
It could well be a heat related type of leak and those can be hard to find at times. A head gasket or sleeve o-ring either one can leak when warm/hot but not leak when cool
[Reply]  [No Email]
Noah in IA
08-13-2012 18:45:47
166.181.3.225
 Re: AC model C - coolant in oil in reply to old, 08-12-2012 14:24:50
old-
I'm starting to think this may be the case (leaks when hot but not cold). I pulled the head tonight and inspected the gasket. I didn't see any obvious blow-outs or staining (of course this is the first head gasket I've ever seen - what other clues on the gasket/mating surfaces should I be looking for?). I checked the head and block mating surfaces with a straight edge and they seemed as true/flat as a framing square can indicate...now on to the possibly interesting part...I took another look up into the engine tonight from where the oil pan would be and noticed some black crud hanging from the outside surface of a couple of the cylinder sleeves where they interface with the block. I reached up in and grabbed a chunk with a needle nose - it appears to be the dried up remnant of an oring?! could this be the case? Could it be that they are so rotten and hardened that they've made their way down the sleeve and exposed themselves? I plan on pulling this sleeve tomorrow night if time allows to further inspect. Please let me know your thoughts - Thanks again all - your advice thus far has been a great help
[Reply]  [No Email]
old
08-13-2012 19:28:02
209.86.226.19
 Re: AC model C - coolant in oil in reply to Noah in IA, 08-13-2012 18:45:47
Could be part of an o-ring but not real likely because if it was the sleeve would most likely leak all the time. As for the head gasket it seals the top of the sleeves and can be easy to leak there if the sleeves do in stick up just a very little bit. The sleeves should sit up just enough that if you run your finger nail over them you should catch you nail on the sleeves. If not then that could be your problem BTDT and had once where the block was planned with the sleeves in and that in turn cause the sleeves to leak
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
