Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Compression on CA
OldMoIron
08-10-2012 22:04:15
How much compression would i get with the 3 7/16 engine rebuild kit from Tisco, or other brands on my CA
Dick L
08-12-2012 06:48:08
 Re: Compression on CA in reply to OldMoIron, 08-10-2012 22:04:15
It will be in the 100 pound range. To many variables to give sure fired answer. To bring the compression up to a larger degree you will need to make the firing chamber smaller.
You can get there in two ways or both. You can get .200 off the head and use a domed piston to enter the firing chamber.
I did both to my pulling B and C.
OldMoIron
08-12-2012 07:34:38
 Re: Compression on CA in reply to Dick L, 08-12-2012 06:48:08
I have been looking for doomed pistons and not having much luck, could you point me in good direction, got the head work figured out. thanks
Dick L
08-12-2012 09:24:03
 Re: Compression on CA in reply to OldMoIron, 08-12-2012 07:34:38
The only domed pistons you will find for this engine will have to be a special order from the hot rod custom piston manufactures or having a machine shop TIG and machine them to fit your application. Both are costly.
I did my own having a tool shop with the equipment.
old
08-11-2012 09:49:40
The compression will be about the same as with the factory sleeves and pistons you just are getting a few more cubic inches of engine so the HP will go up a little bit
