D-19 clutch
Anonymous-0
Can someone please give me the factory specs for the thickness of the clutch disc on a D-19. I have had 2 sent to me so far and they are too thick. There is no adjustment left on the fingers of the pressure plate. I sent the original one in for core and have nothing to go by. I just received one I ordered from an Agco dealer that assured me was the proper thickness is an aftermarket and it is also too thick.
How do you know it's too thick?
What is the step measurement of your flywheel? If the step is not the right dimension, no disc will fit. If you've had 2 different discs in it, and still have a problem, look at something else.
Chris
