Anonymous-0
I have a 190 on its last legs. I was going to move it out of the way so I could pour concrete. It started (with a good shot of ether) and run about 2 minute then died right in the driveway. I have replaced the fuel filter, cleaned the sediment bowl, blew out the fuel lines, and cleaned the screen on the inlet to the pump. I also inserted a fuel pump between the filter and the pump. It will start and run for 2 -5 seconds then dies. the longer I leave it sit, the longer it will run but not long enough to get it moved, plus it has a loader on it so pulling it is out of the question where it is sitting right now. Any suggestions?
