Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: CA govenor
[Return to Forum]
OldMoIron
08-05-2012 18:41:52
71.1.126.144
I need some tips on tuning up my CA it seems it lags under pull. As when letting out the clutch in 3rd gear. Is there some adjustment that can be done. thanks
[Reply]   [No Email]
old
08-06-2012 08:30:13
209.86.226.59
 Re: CA govenor in reply to OldMoIron, 08-05-2012 18:41:52
A problem like that can be caused by many things. Needing a simple tune up or a carb rebuild or as simple as a weak spring. Hard for us to help you with out more info as to what you may or may not have done already
[Reply]  [No Email]
Dick L
08-05-2012 19:35:11
50.51.157.154
What all have you done to the engine?
[Reply]  [No Email]
OldMoIron
08-06-2012 16:36:25
71.1.126.144
 Re: CA govenor in reply to Dick L, 08-05-2012 19:35:11
thanks Dick for reply, The thing has sit for awhile. Drained old gas,put in new, cleaned air filter/oil, cleaned plugs, checked wires for breaks, filed points readjusted. reset dwell. checked air fuel mixture, and timing. sorry to go on and on, Trying to let ya know. thanks
[Reply]  [No Email]
Dick L
08-07-2012 08:49:54
184.8.54.44
 Re: CA govenor in reply to OldMoIron, 08-06-2012 16:36:25
Only a guess but I would think it would come around with some hard work and a can of sea foam. Half in the crankcase and half in a half tank of gas. It sounds like it is a bit shy on compression or HP. Same deal when you are talking third gear.
A governor is a RPM limitor or is to hold the RPM up under load provided you have the HP to hold that load at that RPM.
My thoughts come from the fact that it sounds like nothing has really been changed in the engine by you before the problem started. If the engine is not wore out working it will get the rings to hold compression up. You can do a compression check as is and them add a few squirts of oil in the spark plug hole and re check the compression before the oil can seep by the rings. If the compression does come up the working then engine should work.
[Reply]  [No Email]
OldMoIron
08-07-2012 18:48:23
71.1.126.144
 Re: CA govenor in reply to Dick L, 08-07-2012 08:49:54
thanks for your help
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
