Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Loose starter on a 49 C
[Return to Forum]
Bruce Bower
08-03-2012 18:58:39
99.47.108.71
The original slotted bolt with a taper that fits into a female machined taper on the starter will not thread all the way through with the starter removed. Is that hole supposed to be threaded all the way through the hole or there some sort of shoulder in the casting? I want to replace with a grade 8 bolt, that has been machined to the taper specs, so I can tighten down the starter properly. I would appreciate comments from you gentlemen. Thanx muchly!
[Reply]   [No Email]
old
08-03-2012 19:45:33
209.86.226.61
Re: Loose starter on a 49 C in reply to Bruce Bower, 08-03-2012 18:58:39
Get a simple tap and clean the treads up on both the hole and the bolt of do as Steve says but if you do what he said make sure you have a nut of so you can use it to clean the treads up or you will have problems
  [Reply]  [No Email]
steve(ill)
08-03-2012 19:34:40
74.36.187.222
Yes, the hole is threaded all the way thru. I have replaced a couple with standard 5/8 NC bolts. just taper the end on the grinder. It dont have to be perfect, it will lock in real simple and make a good ground.
  [Reply]  [No Email]
Ted in NE-OH
08-03-2012 19:26:49
98.20.254.192
I would think it should be threaded all the way thru. If it isn't and that's a problem, it should be an easy fix.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
