| Allis Chalmers Discussion Forum |
Topic: D17 lean on #3
[Return to Forum]
| Author |
[Modern View]
| Wingswd
07-28-2012 08:45:44
67.142.168.24
Working on a 62 Series 3 D17 with a slight exhaust backfire. Plugs show #3 being very lean. wires are new, compression good, head is off and valves are alright. Any ideas and what plugs should it have in it. |
[Reply] [No Email] | |
| old
07-28-2012 11:08:16
209.86.226.40
Re: D17 lean on #3 in reply to Wingswd, 07-28-2012 08:45:44
| If running lean on just one cylinder that almost has to be something wrong with the manifold as in a clog or a crack. Spark plugs will not change a rich or lean condition. Now then a intake valve that does not open as wide as it should would or even an exhaust valve not opening as it should would cause that. As for the back fire that is the by product of it running lean |
| Wingswd
07-29-2012 06:44:04
67.142.168.24
Re: D17 lean on #3 in reply to old, 07-28-2012 11:08:16
| Thanks old, I'm just going to keep checking things. Lap the valves, set the valves, get it all back together and hope for the best. As for the plugs I just wanted to make sure I had the right ones in it. |
| old
07-29-2012 09:04:05
209.86.226.32
Re: D17 lean on #3 in reply to Wingswd, 07-29-2012 06:44:04
| Another thing that could have cause that is a bad manifold gasket and leaking air at the #3 intake area of it |
| Wingswd
07-29-2012 18:38:53
67.142.168.23
Re: D17 lean on #3 in reply to old, 07-29-2012 09:04:05
| I thought of that but 3 and 4 share a port |
| BushogPapa
07-29-2012 19:42:31
173.88.51.117
Re: D17 lean on #3 in reply to Wingswd, 07-29-2012 18:38:53
| At that point, you need to "think like a JD Man".! All the older 2-cylinder JD's with a Single throat carb has the same problem.. The Leading cylinder Hogs the majority of the inlet charge and the trailing cylinder "Loafs".. That would not normally be a problem..but..IF you had a leaking gasket...there could end up being a Lean condition.. And, as OLD said..even a worn cam lobe or worn cam bearings could cause these symptoms.. Ron.. |
| BushogPapa
07-29-2012 19:40:09
173.88.51.117
| Wingswd
07-30-2012 19:21:33
67.142.168.24
Re: D17 lean on #3 in reply to BushogPapa, 07-29-2012 19:40:09
| Thanks to both that does make sense |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
