Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1939 Allis Chalmers B
[Return to Forum]
Paul Simmer
07-24-2012 11:41:32
75.40.244.2
I just brought home a 1939 B that originally belonged to my Grandfather. It hasn't run for years, but has been inside. The crank hole which is part of the radiator support is really egged out. It appears there is a extra thickness piece that is standard on these, and it too is bad. Has there been any sort of repair piece designed to weld or bolt over that original hole? I am sure I could remove it and have it built up and turned back to original size, just wondered if anyone designed a repair piece. Thanks.
[Reply]   [No Email]
Paul Simmer
07-25-2012 09:35:18
75.40.244.2
Re: 1939 Allis Chalmers B in reply to Paul Simmer, 07-24-2012 11:41:32
Thanks. Because that is basically a "wear point" at least for the crank start models, I was hoping they made a repair part that welded in place. It is a nice little tractor, and because it belonged to my Grandpa it is even more special.
  [Reply]  [No Email]
chalmersbob(pa)
07-24-2012 19:33:35
173.62.135.176
The part you need is called the "radiator support". There are usually some on Ebay. I don't know of a repair kit for it, but if you have a welder, or know of a welder it can be repaired. You can either weld it up or make a new piece of metal and cut the proper hole into it, then weld itin place. Great little tractor. Bob
  [Reply]  [No Email]
Paul Simmer
07-24-2012 13:25:38
75.40.244.2
I have it running, it is just real hard to crank with that slop in the crank slot, plus it is wearing in the sheet metal. I was hoping they made a thicker piece of steel that was designed to repair that worn slot by bolting over it or tack welding it or something. Thanks.
  [Reply]  [No Email]
old
07-24-2012 12:28:20
209.86.226.32
Behind that sheet metal should be another bracket that the crank handle goes threw and it is around 5/16 thick and is there to keep the sheet metal good. I probably have 2 or 3 of them laying around on parts tractor I have. Also if parked for more then a year I would fill the cylinders with ATF and also pour ATF down the exhaust and let it sit a week before I would even try to turn the engine over
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
