| Allis Chalmers Discussion Forum |
Topic: D15 dies suddenly starter dead for minutes
[Return to Forum]
| Author |
[Modern View]
| Joseph Wayland
07-18-2012 05:12:10
216.228.216.162
My usually reliable D15 has developed an electrical problem which I hope someone can help me solve. Often attempts to start results in absolutely nothing - no sound or action. Repeated pushing of the starter button eventually gets action. Also on occasion the running engine will quit suddenly as if the key were turned-off. Finally when turned off for a while, the battery goes dead (although it charges when running). I think I must have a short - perhaps in the key- switch? Would appreciate anyone's guidance. |
| Diydave
07-18-2012 17:32:15
96.244.164.17
Re: D15 dies suddenly starter dead for minutes in reply to Joseph Wayland, 07-18-2012 05:12:10
| I'd start by checking the connections, at battery with a carbon pile load tester. Attach the clamps to the battery connection, after it quits. If it shows low voltage/ bad battery, remove the wires from the battery, and re-test. If you have good voltage, at battery, check the ground. If that checks out good, then move on to solenoid, key switch, and ignition. Do you have a heavy ring of keys on the switch? If so, try lightening the side load on the key. Also be sure to check the little square piece of bakelite, that carries the hot wire through to the points. |
| old
07-18-2012 09:16:15
209.86.226.40
| Well first off you sound like you have poor battery connections remember clean tight and bright. As for the battery going dead sounds like you have a V.R. that has sticking points in it so as not to shut off like it should do it drains the battery when sitting. As for it dieing out that sounds like a loose wire some place which in turn goes back to the clean tight and bright which hold true at all connections |
| Bob Bancroft
07-18-2012 08:30:52
97.73.64.148
| I would say all your main connections are suspect. The good news is on that tractor they're small and close together. I would start with checking, or maybe even just replacing the solenoid, down on the starter. And of course, all connections right from the battery(to ground) and to the solenoid, then back to the ammeter/dash, etc. are all suspect. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
