Jim Comfort
New User
Now that I can put some pics up, I'll give you a bit more detail. First, I mentioned that the front end had something attached to the front end left tie rod...here it is:
As for the sloppy steering I mentioned, there's a lot of play in the steering wheel, so I'm guessing that my problem lies in here:
The guys in my other post were right about the snap coupler under the seat, but my problem is with the handle, in that there's not enough room for the handle to disconnect:
Here's my 3 point with the snap coupler:
Am I better off just dropping the implements and putting them all on the same snap coupler assembly (if so, I'll want to find something a little better than the nut and bolt system it currently has for the implements)?
I noticed the front tire seems to be rubbing on the tie rod end. Does this look like it's adjusted right?
Finally, I've had to jump start the battery every morning. I was told when I got the rig that the battery was only a year old. I noticed that the ammeter shows discharge when the light switch is in either position, but I never see a charge. Do I need to try repolarizing the generator? Am I right in assuming that this is the cut out box (the box mounted on the generator)?
That ought to be enough aggravation for some of the old timers to try to sort out, so I'll give you guys a break. Thanks for any advice/assistance in advance.
