This is a 5 ft WOODS mower on a C. It has a mechanical lift. I would think you could mount something like that on any tractor with a few modifications. Biggest problem is getting the pulleys lined up outback to route the belt to the deck... or are you going to use a trail mower and drive shaft ? Could just be wheel mounted ?
<a href="http://s436.photobucket.com/albums/qq86/steve-ill/?action=view&amp;current=no6finalpaint005.jpg" target="_blank">
no6finalpaint005.jpg" border="0" alt="B with woods deck
</a>
I assume you are referring to the AC one that mounts just behind the tranny? They show up from time to time on eBay. Trick is they are pretty heavy and don't ship cheap. I'm sure if you put a want ad up here, someone would have one.
AaronSEIA
Are you talking about the cultivator lift that works off the transmission area of the tractor or are you talking about the hand lift?? I have one of those cultivator type lifts I would sell but shipping would be hard since it is not light
Steve, could you tell me the size of the spring on there? How big around and how long when closed?
Thanks, Ted
That is a B allis. If your going to put a Woods on a WC the Hand lift is the way to go. you can still order from woods it just takes a while to get non stocked parts. The belt for a WC drives off a large pulley that mounts on the PTO. You don"t want the mechinical lift you must be moving foward for it to lift. it will not lift if your standing still. and it drops suddenly when released.
I would say you are on the wrong track, but there are ac plows with the exact same unit on them.
I have a few in NE Iowa if you are close.
I live in Missouri the Lake of the Ozarks area. My e-mail is always open on here
