200 hydraulic pto front shaft housing removal
180doug
In the book it says when you remove the pto front shaft housing you must ENGAGE THE PTO SLIDING COUPLER - IF NOT IT WILL FALL TO THE BOTTOM OF POWERDIRECTOR HOUSING - ok, how do you do that ?? There is no lever on the side of the PD housing to move this coupler as there would be on a mechanical pto tractor , its all hydraulic ; how do i do this ?
Did you find out how to do this? We have a 190XT that the PTO does not work at all, any ideas on troubleshooting this problem?
