I've never used the classified adds and with horribly slow internet it would be nearly impossible to do so if anybody has a set of used tie rods for a WD45/D series they'd let go for a fair price please pm me.
Luke
Luke, I didnt see how to PM you.....maybe you can respond to this reply in PM
I"ve got a good set of used ones from a D17 and IIRC, the ones from a WD or WD45 are not the same. (the adjustment marks start place is different)
Both sets have new zerks. The telescoping parts have been disassembled and trued up to make sure they extend & retract correctly.
The ball-ends are tight. The over-sized clamp nuts are missing. I can take a few pix if you like.
Gatz
Apparently private messaging is under construction...still... As long as the bolts at the ends are the same I'm ure they would do the trick. I had to beat the old ones out with the sledge after ruining my pickle fork with the air hammer. The sledge rounded the heads off and I couldn't get the tap to take on them. picks would be nice, but I'm sure they're as good as you say they are. what would you have to have for them and where are you located?
Luke,
try emailing me via the link that shows up in the lower right corner of this reply box...see if that works.
I'll need to consider your offer. local Worthingtons said he could order the ends for $57, so $60 for the whole dang thing sounds like a pretty fine deal, Right now my only problem is money, I have a fiberglass tonneau cover for sale, and once it's sold I'll have the money for sure.
I just priced and ordered one from A&I for $45 for one complet side for my D17 and it said fits WD WD45 and D17. I think it was $35 for just the outer tierod end, For that price I just ordered the hole thing. I will hang on to the good end for future use. Bandit
