Model G sickle mount
Yukon3639
I am looking for the dimensions of the plate that hangs the mower unit to the G frame at the split. The mount for the mower is not the same bolt pattern as the main frame connecting bolts and it is my guess that an adapter plate will hang the mower lower .
Thanks for any help Anyone can send my way.
I made my plate from dimensions I got from someone else. The plate is 8 1/2 X 5 X 3/8. Top set of holes are 1 1/8" down and 1 1/4" in from the left and 6" center to center. Second set of holes are 3 7/8" down and 3/4" from the left and 5 1/2" center to center plus a third hole another 1 1/2" over from the second hole for the pin to slide into. Hopefully the photo works.
Another try at a pic.
My parts book show a mounting plate #316707, held on with 2 5/8" X 1 1/2 ' and 2 5/8" X 2 3/4" bolts The plate appears to be about 4" tall and as wide as the front mount on the mower.
Bob
(quoted from post at 11:01:06 07/30/11) I am looking for the dimensions of the plate that hangs the mower unit to the G frame at the split. The mount for the mower is not the same bolt pattern as the main frame connecting bolts and it is my guess that an adapter plate will hang the mower lower .
Thank you very much. Will go together tomorrow
bob
