The distributer got messed up on my friends Allis CA during a project. I am trying to help set the distributer properly and I am having some troble.
The tractor has a coil ignition and is still 6v. Just let me know if you need any other background info.
The biggest problem I am having is where is cyl 1? From the sounds of the manual all I have to do it pull the #1 plug, wait for pressure, and look for the fire mark on the flywheel. Then I turn it until I see the DC.
I turned the engine until the first cyl (The one closest to the front/radiator) was at TDC. Then when looking at the rotor it was pointing towards the rear most cylinder's wire. This leads me to believe #1 may be the rear cyl??? Once I get that part straight it sounds pretty easy.
Any tips or parts I am missing would be great. Thanks again!
