Will Herring
I replaced the sediment bowl and valve assembly in 2003 with a whole new part as the original was falling apart on this old girl... However, within the last year or so, the new shutoff valve has been leaking around the valve stem. When you have it open and the gas is on, it seems to be okay, but when you turn the gas off it leaks out.
What would the proper name be for the part I need to replace on this without having to buy a whole new sediment bowl/gas valve assembly?
Like, it is just a needle valve or something? Or, can I just buy something to make my own packing with?
I hesitate to pull the old one off of there until I have a solution, but I ran the tractor about out of gas today, so I hope to fix the problem in the coming week or two.
