auburn clutch
plowboy69
New User
I hava an HD6 track loader. The cluth needs adjusting and it seems to be froze up. any info on how to make my adjustments will be a huge help.The tractor does move but slips a little under a load.
You need to removed the floor plate and the inspection cluch plate housing and desangage the the cluch and turne the cluch until you see the hexagone head screw and loosen the adjusting ring locking screw just enough so that the cluch adjusting ring can be turned,tighten the cluch by turning the notch cluch adjusting ring clockwise with a srewdriver until the proper adjustement is obtained and you need 25 to 30 pound on the cluch lever.
