1941FarmallAboy
A buddy of mine has a 1949 WD. When we are working with the Wd We have to hold the Throttle Lever down, If we let go it will just slide back up to low Idle, How do ya fix that? Its a pain when ya are cuttin brush!
When ya press in the clutch the brakes also get pressd in, We took of the cover and back'd the brakes off some but it still does it! It does have a hand clutch.
Now the steering!!!! It use to be really easy to steer UNTELL a friend put new gear oil in the front bolster! I think he messd with the bolts on the bottem of the ______??? WHAT DO YA CALL IT? Ya have to take of one of the front tires to get to it! There is one on the bottem and a set nut/bolt about an inch up from it!
Thanks!!!!
Thanks!!!!
