I live on a small 'farm' of 11 acres and currently I have a big tractor (too big) IH856 Diesel, a project tractor 52 CoOp E4 with unknown 6cyl Buda Motor and a Cub Cadet lawnmower. No real 'medium sized' tractor.
I have the opportunity to acquire 2 WDs, whether I end up with these or not I will be working on them, because the person I will be getting them from is Dad and one of us will use them.
(1) Wide front wd45 (WFWD)
(1) narrow front WD (NFWD, not certain if it is a 45 or not)
Dad has another WD narrow front with loader that he uses for his yard tasks. (off limits)
The WFWD has a 'stuck' motor in it and is missing the gas tank and I've been told that the first gear is 'out' because the previous owner pushed a lot of snow in 'low gear'. I've never seen the NFWD but Dad assures me that it does not have a motor and that the 'tin' is there.
So I am fairly certain that I can have 1 whole tractor out of the parts from these 2.
I have a ton of questions about these tractors and am wondering if it's best to separate them all out into individual threads or just one massive one. The topcis of these threads really runs the gambit too..
1. favorite methods of unsticking a motor (leave it sealed up or open it)
2. Hydraulic system repairs and modification
3. Hydraulic system capabilities (loader/implements)
4. 3pt conversions
5. Loaders, what fits and what doesn't
6. Motor conversions, I have access to a spare Buda 6cyl gas, how much would it take to swap it onto the motorless narrow front, or if I can't get the WD45 4cyl 'free' I might need one on there.
7. If 1st gear is 'out' does that typically indicate a broke/worn gear or are there bearings/bushing/guides that wear out, and how hard is it to repair?
8. Wet Clutch repair. On Dad's working Narrow Front, the hand clutch no longer works but the foot clutch does, what would cause that? And how do you repair it?
9. Anybody ever built their own 3pt system?
10. How do I know which color stickers to use on it when it gets rebuilt? black or blue? Long A and S or does it matter?
11. I need to be able to move 1200-1300lb round bales, what is a safe operating limit for the front axle on these tractors?
12. While talking about frontends which is stronger Narrow or Front? (I have my option, see above)
13. Is narrow or wide a better overall option for me considering that I also plan on 'brush hogging' and ditch mowing with this tractor?
14. Rear tire liquid filling. The WFWD has 2 sets of weights on each rear tire, if I hang a 7ft snowblower off a 3pt will I need the additional weight of calcium chloride if move round bales?
15. How much HP/TQ can I reasonable expect to get out of the 4cyl? Stock specs look like the reside between 30 and 40 depending on belt/drawbar/pulley, can this tractor be coerced to put out closer to 50-55hp (or more) with upgrades to head/compression/cam/carb size/increase governor max speed?
16. Has anybody ever ran a belly mower on these? (what size)
17. What is the min and max width for tire/axle width on these tractors? (I saw this one day but neglected to save the information for when you have the power Z rims and spin them fully in and out)
If I had one tractor that could do the following I could retire the rest of them (not the lawnmower)
pasture dragging
[b:6444060bdd]Loader work[/b:6444060bdd]
round bale moving
[b:6444060bdd]3pt mounted utility stuff[/b:6444060bdd]
snowblowing
hole augering
rototilling
mowing (finish and rotary)
Weed Spraying
Driveway Blading
What I really need are some knowledgeable Allis Chalmers people who like tractors and like to talk/type about them.
For any information that you can give me, or direction on where I can help myself, websites books I'd appreciate it.
Thanks,
-ron
4. 3pt conversions
pasture dragging
round bale moving
snowblowing
hole augering
rototilling
Weed Spraying
Driveway Blading
Thanks,
-ron
