39 B with unknown history. Got it running after it sat for a couple years since it last ran according to the last owner it was running good but the magneto went out.
A fresh mag and gas it fired right up on the second hand crank. New plug, wires and moved it around the yard for about 10 minutes getting it warm. No smoke and no leaks. Pulled it in the garage and drained the oil which was full but black and thin.
New 20w50 and a fresh filter....would not start....ended up pull starting it and it is blowing blue oil smoke. Not tons but it is vsible. Runs okay but will not start without pulling it and when I increase throttle it lets go with a puff of blue.
Gona do a compression test this weekend but I am limited in my scope of ideas...rings or valves? Did the fresh oil clean away or stick something. What say you mechanic guys that have BTDT. Coincidence? Any methods to help ID the needed fix? Leakdown test on the cylinders? The not starting by hand crank seems odd. It is timed and runs okay once running but for the oil smoke.
Appreciate your thoughts. I am gonna save this one so it is going to get fixed one way or another.
