B, C Drawbar Pins....Are they available?
rasman57
Are the drawbar to axle pin sets available repro or does anyone have a source for these? For a B or C Thanks Ralph
I would say that 7 bucks plus shipping would be about ten times what they are worth as bad of shape they are in.
If you have a drill press, a 3/4" drill bit, a 7/8" drill bit, at lest 4 inches of 7/8" steel round rod to make two 2 " long 7/8 pins and a piece of 3/8 inch thick strap iron 1 1/4 inch wide that you can cut two hunks 5 1/8 inches long all you need to is weld the 7/8" rod in the 7/8 inch hole after drilling the holes on 3 3/4" centers. The 3/4" hole is centered 3/4" in from the end.
That is enough information to make drawing to make new ones. Machine shop 101. Measure, mark, cut, drill, weld.
Here is a brandy new one I just measured for the above.
Wow that is some nice work. I am pretty handy but do not have the gear to produce a set. You should sell some....guys like me would buy a set for the show tractors. Email me Dick. Thanks Ralph
I have a mold making tool shop but didn't make that one. It was my understanding when I bought a tractor from I guy that he bought this pair from AGCO. I can't make stuff to sell as I am so far behind on mold engineering changes and along with insert changes on existing tools that I would never get to it.
I was just giving the information for you or anyone to make them if you or they have the tooling.
