Hydraulic question
Rusty Smith
New User
I have a C model Allis, the hydraulics that are on it are factory, it has only one cylinder. Does any one know about how much weight it can lift? I am putting a 3 point scraper blade on it, and it weighs about 200 lbs, can it do it?
If you look close the cylinder mounts it has are set up so 2 can be used. My self I use a cylinder off a WD or WD45 in place of the stock cylinder so as to get more lift and a little longer stroke. As for how much that one will lift well lets just say it will surprise you since I know when I still had my B it would lift a plow that was stuck in the ground and almost lift the front end
the cylinder had 3200 psi pressure, acting on a small piston, but it will put out about 2000 pounds of FORCE or push. You have to see what mechanical advantage that cylinder has thru the ling dimensios, but YES it will lift a 200 pound blade, if the linkage is right, but it is very close. I also have used a WD cylinder on my conversions. I have one that uses a CA cylinder. Both are about twice aa big diameter as the C.
