Ok so, this is a 1970's Allis tractor, once again, I cannot remember the model number. It has a cab, no bucket, fairly large tractor.
The problem is, when you start it, the hydraulics simply do not work. You can leave it run all day long, and if you go back to try it, they still will not work. The only way to get them to work, is to take a large bolt out of the hydraulic pump on the engine, rev it up for a bit, and then it will start to work. Sometimes after 20 minutes of forcing the steering wheel around, it might start to work.
The owner of the tractor is convinced he has all the air out of the system. He has had the tractor for 20 years, it did it ever since he bought it, he had the hydraulic pump rebuilt a few years ago, and it still continues to do it to this day.
What would make the hydraulics lose there prime, IF that is, what it is? This tractor has me stumped.
If I could get some help on where to start, I would really appreciate it, thank you!
