F2 injection timing
2strk2cyl
had to pull the pump out of the old f2, found there are no timing marks on the gears, i know how to find the timing marks on the pump itself, but where are the timing marks on the engine, is there a pin to lock the flywheel? if not, what degree should it be at, where are the degree hash marks? thanks for any help.
sorry, 4 i found the marks on the dampner after taking a wire brush to it, set it at 18 deg and it seemed to run fine.
