First off let me say hello to all, I am new here. I just recently started working on farm equipment for a co-worker of mine, I am very mechanically inclined, but don't have papers. He on the other hand, not so much haha.
I am having a problem with an old Allis tractor of his (cannot remember the model, sorry) that has stumped me. It is a diesel, no bucket, has a cab. It is a 3 wire alternator, not a delco or anything, it's the one specifically meant for that tractor, he says he special ordered it, cost him big $$
He came to me one day claiming that he could park the tractor overnight, come back in the morning and it is dead. It would start with a boost right off the bat, but not by itself. So I went out there with my multi-meter and test light, did some poking around. When I tested for parasitic draw, it was drawing about .60 MA with key shut off, way to much. Now, the big stud terminal for POS on the alternator, the small wire hooked off of that, to the far spade terminal just a few inches over, if you unhook that small wire, the drain stops.
Now, he tells me that a wire has burnt off, somewhere just under the "hood" so I take a look. There was about a 10 gauge wire, coming off the alternator, to a small brown plastic clip, with 3 connection points on it. Only one of which was being used, from there, a smaller 14 gauge wire, ran up to the ignition, as far as I could see. This plastic clip melted, and ever since, these problems have been occurring, according to him, this is when this all started.
Now, with the tractor running, and that wire unhooked as the clip is burnt off, it is charging at 17 volts, putting out 30 AMPS on the amp gauge on the dash. If we hook those 2 wires back up together, it charges at 14.8, and the amp gauge drops to 15 AMPS on the dash. Problem is, even with those 2 wires hooked back up like they used to be, it still drains at .60 MA with everything shut off. Also, if we leave those 2 hooked up, they become VERY hot, especially the smaller gauge one obviously. There is no light on the dash for voltage, just an amp gauge.
What is this and what am I doing wrong? I can't figure this out. Every night he has to unplug the wires from the 2 spade terminals to stop the drain, and then it starts just fine the next morning. If you leave them plugged in, it sucks the battery away.
I would really appreciate some help into this, I am stumped.
