alis charmers c
ok i finally brought it home bought it last fall well started rebuilding it today tore motor down it needs crank, head'(rocker assemably because its missing) one conecting rod, piston and sleeve kit, gasket kit, water pump,radater,intake exhust manifold and carb is missing to. clutch the mag has no fire and who know what else it will need
I have a lot of those parts laying around. I also have 2 parts you do not find often. I have a cast iron oil pan and a cast iron valve cover for a B/C engine
Hobby farm
What makes you think you need crank/rod ? Most can be turned/built-up and turned unless broken. Unless I'm missing alot those cylinders don't look as bad as some, sure didn't look rusted.
it had been stuck and had a grove in two of the four cyinders that i thought might break a ring so i an just going to replace them
