My two Allis books (operator's manual and service manual) are not very clear about exactly where to lube the final drives and what to use. They make mention of a very thick gear oil, over 200W. I haven't seen that at the local suppliers. I see a drain plug on each final drive cover but don't understand how or where to add the lube. There appear to be fiber plugs, on each side towards the front side of the housing. Do I remove those and lube using a needle nose fitting? Any help appreciated, thanks.
Also, any suggestions on other service and repair manuals I should look for, that might be more detailed? Prefer printed instead of DVDs.
