e gleaner motor in wc
39f20
Im wanting to put a e gleaner engine in my wc, do i use the flywheel out of my wc, and which governor do i use, thankyou for your info
You will need a tractor governor. The combine is set for high idle. WD45 or D17 governor would work. Some flywheels on the D17 or Gleaner E combines were larger to accomodate a larger clutch (1 inch larger) If memory serves me you can stick with your WC flywheel.
