MT in Walford
Hi,
I bought a 1950 WD. The electrical system is modified a little. It has a regulator, and DOES NOT have the cut out box or custom light switch anymore. It is 6 volt positive ground. I am having trouble getting it to charge and wonder if they had it wired right. So do you all know of any wiring diagram so I can check to see if it is wired right? Thanks for your help.
Mike in Iowa
Mike in Iowa
