Need info on a 1940 WC
jeffy0023
New User
Hello, Just bought a 1940 WC have not seen up close yet this is my first old tractor project. Will be using it as a resto project but also for some land managment on our hunting property. Does this model and year have a 3 point hith? - Does it have a draw bar? - what type of bush hog and plow set up do I need for this tractor? - your knowledge is greatly appreciated. Jeff
WC has no hyds. so no 3 point. I should have a swinging draw bar of some sort but those can be removed so that a maybe. For that you would need a pull type plow and a pull type brush hog
Hobby farm
It has a drawbar but no 3 point hitch or hydraulics. It pulls a 2-14" or 2-16" plow with mechanical clutch. If it has the power take off option, it would pull a trailer type bush hog with a mechanical screw jack to adjust the height.
I'm currently adding hydraulics and a three point hitch to my WC so that I can use a three point shredder. The plow will still need to be pull type.
Thank you I know the type of bush hog your refering to. The tractor does have the PTO and also the belt hook up on the side which I think would be fun to run something like a saw or log splitter off of if I could find one, I"ll have to watch the auctions. Jeff
