Restoration Story
1964 JD 2010 Diesel - Part 4
by Jim Nielsen
Part One,
Part Two,
Part Three
Yes, It works!
The main engine
components needed to complete the assembly of my 1964 JD 2010 diesel, took a
couple of weeks to arrive at the 'local' John Deere dealer. The key items included
the pistons, sleeve plate, con rod bearings and rings. Now for some real
tractor fun - putting my 1st engine back together - and seeing if it would run!
First for the sleeve plate. I'd had a devil of a job getting the old
plate out, and had been very careful to ensure that the mating surfaces inside
the block were as clean as possible to take the new plate. I put some 'dish
soap' on the rubber "O" rings (the small
flimsy things that sit between the sides of the block and the sleeves), which
are used to prevent the ingress of water. I then sat the lower sleeve gasket on
the block and attempted to get the sleeves to fit. The plate is a VERY tight
fit between the bottom of the sleeves and the top of the appropriate holes
inside the block. I had to do a fair bit of jiggling to
get it in but I managed it. The problem is that the sleeves are welded onto the
sleeve deck, and the block is a 'cast' component, therefore the slightest
warping in the plate or block would certainly prevent them from mating; as any
movement in the plate needed to fit the sleeves in one cylinder would make the
other three not fit. Also, my manual was emphatic about the need for 'ring dowels' to "locate" the plate and I didn't
have any - happily I found the old ones still sitting, waiting for me in the
old sleeve plate. It was great to see the plate sitting
in the block - it almost made me feel like I knew what I was doing! It had
been my opinion that the plate would be the hardest item to deal with - but
that was before I'd wrestled with the pistons!
As instructed by the manual, I popped in a couple of short
bolts to secure the plate to the block while I installed the pistons - I
certainly wouldn't want the plate lifting up and unseating itself! Now I'd
never seen a new piston up close before, they sure are
shiny! Almost makes me think they were worth the $600 USD I paid for them! (Oh
and another $600 USD for the plate!!) First the piston pins and clips. The old
pins measured up ok, so I decided to reuse them (that saved me $400 USD) but I
bought new clips just in case. As soon as I tried to put the pins in the
pistons, I realized there was a bit of a problem. They are supposed to be a
'thumb' press fit, but my poor thumbs sure couldn't press them in - and these
pins have to be 35 years old - so they must be at least a little slimmer than
new ones. I took the problem to Repco, my local engineering works, and they
told me that it would be best to let then ream the pins / pistons to fit each
other (a mere $100 USD) so after a weeks delay I got them back. I must say that
the pins were fitted to the pistons in a way that they moved freely, but
without the merest hint of looseness - probably $100 well spent. While Repco
had the conrods to install the pins in the pistons, some over zealous Repco
engineer also decided that the conrod big ends were
somewhat out of round so I let them ream them back to round as well - and trim
the bearings caps accordingly. Yes, yet another $100 for that, but I didn't
want to ruin the conrod bearings that I'd paid $500 for!!
Having got the whole shebang back home, I was now in a
position to install the piston rings using my friend Mal's ancient piston ring
expander - but I decided that one last ( I hoped) investment at Repco would pay
off though, so I shelled out $15 on a shiny new piston
ring expander - I didn't want to damage the $500 ring set!! Now the shop
manual describes how to make a set of wooden 'teeth' so as not to damage the
piston assembly as you pop each one in your bench vise to install the rings.
Unfortunately, I didn't have a vise at that stage, (Mal later took pity on me
and bought me one!) so I adapted a cardboard box for the
purpose and it worked like a charm. Hey, who needs 'special' tools! Putting the
rings on was a lot easier than I'd expected, the new
tool worked very well. Now to install the pistons.
It looked like it should be easy enough: oil up the cylinder bore and piston,
pop on the ring compressor and slot that piston right into the hole! Yes? Well,
it didn't go that way. On my first attempt to install a piston, I was quite
devastated to discover that the bottom of the piston did not even look like
fitting into the cylinder bore - let alone the damn rings. Remember I'm using
brand new standard size sleeves and pistons. I discovered, however, after a
small bout of depression that you had to have the piston EXACTLY square in the
cylinder bore for it to fit. It says in the manual that the pistons are 'cam
ground' and so I assumed they were not exactly round in shape - but they LOOK
perfectly round. Anyway, when I aligned the piston exactly, it suddenly seemed
to magically shrink in size and dropped down to the bottom of the ring
compressor. It took me quite a while to get the piston rings through the compressor and into the bore properly, but I did,
without too much persuasion from the back end of my hammer. It took me about
3/4 of an hour to get the 1st piston installed and the conrod
bearings and bolts in - then about 3/4 of an hour for the other 3 - so I
was definitely getting more used to the process by the time I was finished!
I felt quite a sense
of achievement, after installing the pistons; at last it looked as though this
engine would one day, again roar into life. Before I called it a day, I installed the oil pump, and then enclosed the whole
bottom end of the engine with the sump and its gasket.
The I&T shop manual that I've been using goes into great and specific
detail as to exactly how to install the oil pump. It is an important procedure
because when you mesh the oil pump gear to the drive gear on the camshaft, it
must be done in a specific manner, as the timing of the diesel injection pump
depends on it. I didn't know it at the time, but following the instructions in
the manual would later lead to several weeks of frustration as I tried to get
the diesel injection timing to work. Blissfully unaware of what was to befall me
however, I felt the full satisfaction of one who has - (almost) - brought an
old engine back from the dead. The following weekend I
hired an engine hoist, and proceeded to remove the engine (as yet with out head
etc.) from the engine stand and reattach it to the
front of the tractor. Firstly we attached the clutch
carefully to the flywheel - only to find - (obviously enough) - you can't
attach the flywheel to the engine if the clutch is already on it! Oops! So
after removing the clutch from the flywheel again so that it could be attached
to the engine - we got started. The flywheel has a locating
pin, which made it easy to place it the correct spot. The clutch, which we
centered by 'sight', was also easily attached. The hoist made it quite easy to
maneuver the engine onto the rear of the tractor, and we had it bolted back on again in a matter of minutes. The 2010 has
a number of very foolish design features, but the most foolish of all must be
the studs on the top rear of the engine. These studs slot into holes at the top
of the clutch housing, yet there is not enough clearance
to get the nuts onto the studs once the engine is attached to the clutch
housing, so you have to slide the engine in just far enough to get a couple of
threads of these studs exposed - while still leaving enough room for the nuts,
then little by little you snug up the bolts as the engine is attached. I'm sure
there MUST have been a reason for designing it this way? All in all the engine
was reattached to the tractor without incident
within an hour, start to finish. Next - while we still had the hoist - we picked up the front axle assembly and reattached it to
the front. The result was a machine that for the first time in months looks
like it might actually be a tractor!
With the device now sporting all its major components, we
installed the head gasket and head, being sure to
torque those bolts down to 150lbs - I don't think
they're going to come loose any time soon. Next came the rocker gear and the
rocker cover - or so I thought. As I was attaching the rocker gear back to the
head - which I'd never disassembled - Mal noticed that one of the rocker arms
moved about 1/2 an inch side to side, making it impossible to set any sort of
sensible valve clearance for that valve. So despite extreme reluctance on my
part, I was persuaded to disassemble the rocker gear
to see what was causing this problem. I was shocked to find that the rocker
shaft had almost worn clear through! It had just a
1/16 of an inch of metal remaining. I am sure if I'd gone ahead and reassembled
the engine with this faulty component it would never have worked correctly, and
it would've taken a lot of time to solve the problem. I was glad to have caught
it at that stage. Unfortunately the rocker gear problem was not in my budget
and my wife was losing patience with the amount of money I'd been spending on
this green devil. I called my JD dealer, hoping for some good news. The rocker
shaft was $200 USD - well could be worse; but the rocker arm bushings - all
worn beyond use - were $50 each and I needed 8 of them. Ouch. Well necessity
being the mother of invention I would need to invent something to salvage this
project. I decided to buy the rocker shaft, then see
if I could have the rocker arm bushings made locally. Repco agreed to make them
for me, and found some that fitted with minimal reaming for the princely sum of
$3 each! Hooray! $3 each!! So I was saved. It took about two weeks for JD to
get the shaft ordered in and another two weeks to get the new rocker arm
bushings made, but soon the new rocker gear system was installed
and we were really getting ready for an engine test run!!
Having installed the rocker gear, and sealed
it in with its gasket, I then set about readying the tractor for an engine
test. I decided to do a basic engine test before proceeding further with the
restoration, as despite having already spent thousands on the engine, I was
still considering the possibility of total failure of the project. I didn't
want to commit any more money to it until I could see some light at the end of
the tunnel. To get the test done, I made up a temporary wiring loom by simply
unraveling the old one and making an exact copy, with little labels on the end
of each wire to tell me where to connect them. I also temporarily installed the
diesel fuel tank, radiator, battery-box, seat,
throttle links etc, in anticipation of taking the 2010 on its 'maiden' voyage.
This process would take longer than I'd anticipated. The diesel
injection pump I had tested (but not overhauled) at a local diesel
mechanics. The test showed that the pump was operating fine, so I planned to
reinstall it on the tractor. I set the timing marks on the pump, as outlined in
the I&T manual, and went to install it on the tractor, but to my horror the
slot on the top of the oil pump designed to engage the
diesel pump was 90 degrees out; there was no way the thing could be bolted in.
As I'd read the manual many times, I was absolutely convinced that I'd
installed the oil pump correctly, so I immediately blamed the mechanic that had
tested the pump, assuming that he'd put it back together incorrectly. He could
not understand how it could be 90 degrees out - 180 yes - but not 90 degrees.
It would take me
three frustrating weeks to find out the answer. I called my JD dealer, who put
me through to a mechanic that had the JD manual for the 2010. We went through
the manual line by line, and I was still convinced that I had installed the oil
pump correctly. It was not until he faxed me the relevant pages that I saw what
I had done wrong. I had installed the oil pump incorrectly because the I&T
manual contains a grave error in the section that tells you how to align the
oil pump - the proper JD manual makes it obvious. So I was on the one hand very
disappointed to have to remove the sump and adjust the oil pump, but on the
other hand very relived to have the problem solved. It looks like my decision
to save a few bucks by not buying a proper John Deere manual had proven a frustrating
mistake. It took about three weeks to resolve the problem with the oil pump /
diesel pump, but finally I was ready to give the engine a try with my friend
Mal assisting. We put a little diesel in the tank and gave it a shot. It took
us a couple of goes to get the fuel system free from air, but as soon as we did
the engine roared back to life, just as sweetly as could be. There was not even
a hint of the black smoke that had been the original catalyst for this project
many months ago. As we were driving it out of the workshop, I attempted to try
a left turn, to avoid the garden fence - and discovered to my surprise that
we'd forgotten to attach the steering drag link - so I almost ran right over
the fence. Happily the brakes worked well. With that little problem attended
to' I then carried out a number of tests with the tractor
including brush hogging a field just to make sure the rest of the tractor was
operational.
Now for what I hope is a 1st in tractor
renovation. I made a digital video of
the morning that we actually got the tractor running (using my wife’s shiny new
JVC GR-DVL-20 digital video camera) and then rendered it into a Real-Video file
using Pinnacle Systems “Studio DV” software.
The files are optimized for 56k modem links and I decided to keep the format
to 120 by 200 pixels to keep the file size manageable. You don’t have to download the files to see
the videos, just click the appropriate icons and the video will be streamed
from the server in real-time. You need
the free client software from Real Networks. It can be downloaded from www.realnetworks.com.
Video 1. The very first time the tractor actually
fires up!
Video 2. The very first time we get the thing to move
under its own power!
Video 3. Test laps of the yard.
When I was satisfied
the engine was going well - not a leak anywhere - I returned it to the workshop
to commence the long process of painting and reassembly. I'm hoping that in a
month or so, I'll have it looking great as well as running great! And hey -
remember I'm new at this! (Well relatively now I guess!) If you want to leave
me some helpful information, please feel free to email me at jim@nielsen.org.
[Comment On This Article] - [View Other Comments]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We've kept the same low rate for six years. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Tractor Manuals
| Tractor Parts
| Forums
Copyright © 1997-2012 Yesterday's Tractor Co. - A Washington State Corporation All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you use antique tractors, collect antique tractors, or just enjoy looking at antique tractors, welcome to our site! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 antique tractor forums, show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
