Tractor
 Parts
We have the parts you need to repair your tractor.  Click Here or call 800-853-2651
Yesterday's Tractors
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   H. Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
Shop for Parts:
Paint Codes Glossary
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Support YT
Subscribe Today!
Contributed Article
Diagnosing Engine Difficulty - Diesel Tractors
The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you.
Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment.
Hard Starting
  • Cold air temperatures.
  • Insufficient fuel.
  • Air traps.
  • Incorrect timing.
  • Loss of compression.
  • Dirty nozzles.
  • Battery charge low.
  • Valve clearance incorrect.
  • Fuel transfer pump faulty.
  • Fuel injection pump faulty.
  • Fuel injection pump out of time.
Engine Overheating
  • Low water level in cooling system.
  • Radiator clogged.
  • Fan belt slipping.
  • Collapsed radiator hose.
  • Thermostat stuck.
  • Engine overloaded.
  • Diluted lubricating oil.
  • Pulling heavy load at reduced RPM.
  • Water pump impeller vanes broken.
Loss of Power
  • Air in fuel line.
  • Restriction in fuel line.
  • Clogged fuel filters.
  • Transfer pump defective.
  • Late injection pump timing.
  • Clogged air cleaner.
  • Sticking valves.
  • Faulty nozzles.
  • High idle RPM too slow.
Irregular Operation
  • Governor control linkage binding.
  • Compression pressure uneven.
  • Valves not seating properly.
  • Faulty fuel nozzles.
  • Low fuel pressure.
  • Low operating temperature.
Excessive Exhaust Smoke
  • Too much fuel to engine.
  • Oil consumption.
Engine Knocking
  • Engine overload.
  • Incorrect fuel.
  • Incorrect timing.
  • Air cell plugged or leaking.
  • Engine RPM too slow.
Home | Tractor Manuals | Tractor Parts | Forums
Copyright © 1997-2012 Yesterday's Tractor Co. - A Washington State Corporation
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you use antique tractors, collect antique tractors, or just enjoy looking at antique tractors, welcome to our site! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 antique tractor forums, show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
