Trailering Your Tractor
By Curtis Von Fange
One of the fun things of summer and fall are the parades and tractor
shows that go on across America. Many owners of tractors travel long
distances to attend these shows and they usually take their restored
iron along with them. Safe trailering practices and inspections will
ensure that the event is a fun one.
A good habit to develop when using a trailer is to give that ‘quick
look over’ before taking it on a trip. Before hooking up to it check
the tongue for proper operation. The latches on the ball hitch, if
that is used, should be free of dirt and debris and should engage the
ball securely without binding. A small dab of grease on the trailer
ball will lubricate the area for your excursion. Try to avoid getting
the grease on your shirt or too much on your hands as it seems to end
up about everywhere if you do.
Go ahead and hook up the trailer to your tow vehicle. Install the
safety chains and plug in the electrical pigtail. Don’t forget to
check the breakaway switch for proper hook up. Turn on the parking
lights and the left turn signal on the tow vehicle. Walk around the
trailer and make sure all the marker lights are working including the
tail lamps. Check the right turn signal and then have a companion step
on the brakes so the brake lights can be checked. Next, take a look at
the tire pressure; a visual isn’t always enough as with dual wheeled
trailers the tires may look fully inflated even when loaded. Look on
the tire sidewall for correct pressure and check with a tire gauge.
These are simple steps that only take a few moments to do and will give
a higher level or security and safety on the road. A more detailed
inspection should be done on a more periodic basis, especially if the
unit is used quite often.
An overlooked place of inspection on a trailer is that of the
framework. Trailers that have been overloaded can develop fatigue
cracks and broken welds. These hidden dangers can only be found by
climbing underneath the unit with a flashlight and a bristle brush and
looking. Areas of particular importance to check are where the
shackles meet the springs, the mounting braces for the tongue, and the
front and rear framing. These areas tend to show up first as the
torsion stresses of the trailer twisting around turns are more
prevalent at these points. Use the brush to clear dirt and debris away
from the welded joints and look for hairline cracks in the welds or on
the steel plates or beams. If found grind them out and reweld or find
a local welder to reinforce the framing.
While underneath the trailer check the wiring for integrity. It
shouldn’t be hanging down dragging the ground or wedged in between
cracks. Make sure it is in proper retainers screwed to the frame.
Rubbing and dangling wires are a primary cause for short circuits and
goofy light action on the trailer. Also make sure that the lights are
properly grounded to the framework. Bad grounds make the lights do
strange things too.
The tires and springs make up the business end of the trailer. This is
where all the loaded weight gets transmitted to the bumps and holes in
the road. Check it carefully. Look closely at the tires. First, look
for checking on the sidewall. Excessive cracks are an indication of
dry rot on the tire. The ultraviolet rays of the sun break down the
rubber on the tire and cause it to dry and contract. This leaves the
inner cords exposed to weathering and dries them out where they are not
very pliable. Road heat and overloading can easily cause a sidewall
blowout on excessively checked tires. Also check the tire for broken
inner cords by running your hand along the tread. You are looking for
small bumps in the tire surface caused by inner cord breakage. Also
look in between the tire treads for fatigue cracks that indicate a
failed casing. One last area to check on tires is the valve stem. Take
the cap off and put a little spit on the end. A leaky stem will blow
you a bubble and be the cause for that slow leak in the tire.
The leaf springs on the trailer should be in alignment with one
another. The retainer brackets should be firm and in place. Check the
spring ends for grease fittings and lubricate. If none are present
make sure that the bushings haven’t wallowed out and that the shackles
are free to rotate back and forth. You might also look for a cracked
leaf spring or a loose shackle bolt. The retainer plate on the bottom
of the axle, which holds the spring assembly, should also be securely
fastened by the two u-bolts. While you are under there take a look at
the backside of the brake assembly. Many designs permit inspection of
the brake shoes, as backing plates are not always present. If none is
present then put the trailer on a jack, remove the wheels and inspect
the brakes. Make sure the shoes have lining and that the magnet is
still functioning. Blow out the accumulated dust and debris with an
air gun making sure to wear a dust mask. Check the wheel bearings for
proper grease as you button it up and don’t overtighten the spindle
nut. Also make sure the lugs on the wheels are properly torqued.
One last area to check is the breakaway switch on the tongue. Most
states require this unit as a backup in case the trailer separates from
the tow vehicle. A small battery in a case provides enough electricity
to engage the electric brakes when the breakaway switch pulls apart.
Hopefully there is enough to stop the trailer from rampaging down the
highway. But that depends on whether or not the wire connections all
are in good working order. When hooked up properly the charging system
on the vehicle will keep the battery trickle charged and ready for
action. Make sure the terminal ends are clean, the battery has ample
electrolyte in it, and the plug ends are clean. Put a volt meter on
the battery to check double check its charge and to make sure it is
receiving a charge through the trailer plug. There is also a small
stainless steel wire attaching the breakaway switch to the frame of the
tow vehicle. Make sure it is not frayed or damaged and has good hookup
connectors on the end which attaches to the vehicle.
All in all taking the time to inspect and properly service a trailer
will be worth the owners while. There is no greater security than
knowing that the unit is safely attached to your vehicle and that it
will reliably deliver that restored tractor to its proper designated
show.
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We've kept the same low rate for six years. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Tractor Manuals
| Tractor Parts
| Forums
Copyright © 1997-2012 Yesterday's Tractor Co. - A Washington State Corporation All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you use antique tractors, collect antique tractors, or just enjoy looking at antique tractors, welcome to our site! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 antique tractor forums, show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
