Tractor
 Parts
We have the parts you need to repair your tractor.  Click Here or call 800-853-2651
Yesterday's Tractors
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   H. Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
Shop for Parts:
Paint Codes Glossary
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Support YT
Subscribe Today!
Contributed Article
Diagnosing Engine Difficulty - Gasoline Tractors
The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you.
Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment.
Engine Fails to Start or Runs Unevenly
  • Fuel valve is shut off.
  • Incorrect fuel in tank.
  • Float valve sticking.
  • Fuel tank empty.
  • Clogged fuel filter or fuel lines.
  • Dirty or clogged air cleaner.
  • Leaking or loose manifold.
  • Engine flooded.
  • Broken wires from distributor to engine.
  • Wires not in proper position.
  • Switch not turned on or defective.
  • Spark plugs wet, dirty or broken.
  • Distributor weak, or out of time.
  • Spark plugs points pitted, dirty or improperly spaced.
Engine Overheated
  • Low water level in cooling system.
  • Radiator clogged.
  • Fan belt slipping.
  • Collapsed radiator hose.
  • Thermostat stuck.
  • Tractor overloaded.
  • Improperly timed ignition.
  • Fuel mixture too lean.
  • Weak spark.
  • Diluted lubricating oil.
  • Pulling heavy load at reduced engine RPM.
  • Water pump impeller vanes broken.
Home | Tractor Manuals | Tractor Parts | Forums
Copyright © 1997-2012 Yesterday's Tractor Co. - A Washington State Corporation
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you use antique tractors, collect antique tractors, or just enjoy looking at antique tractors, welcome to our site! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 antique tractor forums, show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
