Bad Vibes
Listening To Your Tractor: Part 4
by Curtis Von Fange
One of the strangest ways to communicate with our tractor is to ask it
how it feels. "Ask it how it feels," you say? Yup, ask it how it
feels. Now, as with the other articles in this series one has to be
able to hear what 'ole blue' is trying to say in response. The nice
thing about our old iron friends is that they are usually quite
consistent in their response, rather unlike some people I know who
might change what they say due to the weather or other mitigating
circumstances. But since this isn't a people communications class
let's look at a couple of examples pertaining to our equipment.
I had a great time bushogging in the pasture the other week. It was
sunny and cool and the grass wasn't so long that the seeds got in the
radiator and overheated the tractor. After cutting a number of acres I
sensed an occasional vibration in the tractor that just didn't feel
right. My 1964 Super Dexta was speaking to me and I needed to listen.
I shut off the bushog and pulled up to the barn. After inspecting the
bushog drivetrain I discovered that the hub that the bushog blades were
connected to had loosed on the drive box shaft. The resulting up and
down movement had wallowed out the mating tines on the gearbox shaft
and created a dangerous vibration which could be felt throughout the
tractor. Had I had ignored the vibration the shaft would have
eventually sheared in two, sending the remaining pieces like missiles up
towards the tractor. It was fortunate that my sensation of something
wrong was felt in the 'bad' vibrations.
Other bad vibes felt on the tractor seat can, many times, be related to
the PTO shaft operations. Dried out or worn universal joints can
contribute substantially to that strange 'feel'. Universals that lack
lubrication will freeze up with rust and dust. As they try to roll
over as the PTO shaft rotates the bearings heat up and may seize in
place creating a flat spot on the race. As the engine continues to
force rotation of the shaft these flat spots create what feels like a
détente in the normal spin of the bearing. This 'bump' can create a
tremendous vibration in the power train that can carry through the
entire tractor. If left un-repaired the universal will eventually seize
and fly apart sending metal shrapnel along with the PTO shaft in
various directions.
Other universal joint problems may occur if the nuts on the u-bolts on
the joint itself come loose. This may cause the cross of the joint to
come loose in the bore and start to rapidly wear from vibration. It
too might break apart under the stresses and revolution speeds of the
PTO shaft.
One other area to check is the squared PTO shaft itself. In order for
the implement to rise up and down with the three point hitch design the
shaft must telescope in and out of a double bored shaft. Adequate
lubrication will keep this in and out operation smooth and keep it from
binding. Also make sure that the shaft rotates true and has no bends
or fatigue cracks in it.
Other areas to check for vibrations depend on whether the tractor is in
motion or not. Idling vibes while stationary can probably be traced to
altered motor parts. Look for a vibration dampener that has a chunk out
of it or has loosened up on the crankshaft. A bent fan blade or loose
water pump bushing will also carry throughout the tractor. Internal
drive parts are harder to locate and should be left to a professional
mechanic. These include miscalibrated crankshaft counterweights, a
broken or loose ring gear on the flywheel, loose clutch parts, a loose
flywheel, or a worn pilot bushing.
If the tractor only vibrates while in motion then look for wheel
related problems. A bent or loose hub, loose wheel weights or lug
nuts, fluid in one tire and not the other, and mud clods on the inside
of the wheel rim are a good place to start. Internal problems could
include worn transmission bearings or a loose rear axle bearing or hub
nut.
All in all bad vibes are bad. This can be yet another place to take
the time to stop and listen as your tractor speaks to you and hopefully
prevent more expensive and time consuming repairs in the future.
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We've kept the same low rate for six years. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Tractor Manuals
| Tractor Parts
| Forums
Copyright © 1997-2012 Yesterday's Tractor Co. - A Washington State Corporation All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you use antique tractors, collect antique tractors, or just enjoy looking at antique tractors, welcome to our site! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 antique tractor forums, show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
